RCU Forums - View Single Post - EVU5 pro question
Old 10-19-2009 | 07:12 PM
SinCityJets
Default RE: EVU5 pro question
Don't do it Pete. If you're having that much of a problem, remove any restrictors you have going to the nose wheel. If you are using the SMC adjustable valve, remove it and put restrictors on the mains only.
The can is the limiting factor of pressure, not so much the valve.
Chad
