RCU Forums - View Single Post - LT-40 flat landing gear
Old 10-19-2009 | 10:12 PM
bryris
Default LT-40 flat landing gear
My landing gear has sort of flattened out a bit. It isn't too bad, but both main wheels run at a slight camber rather than vertical. I pulled the tie down pieces and cannot seem to remove the gear struts from the blocks to manually rebend them. I am afraid that if I bend them in the blocks, I'll do some damage.
What is the best way to get a little height back here? Or should I just leave it alone? The tail rides about 3 inches or so off the ground. Doesn't allow for much pitch error on landing.
Thanks.
