RCU Forums - View Single Post - Wrapping the ignition's battery pack in alum foil ....
Old 10-20-2009 | 06:12 AM
Tada
My Feedback: (13)
Default RE: Wrapping the ignition's battery pack in alum foil ....
ORIGINAL: cuwaert
Shielding must be grounded or it may work inverse, so more problems with ungrounded shielding.... and you know what, there is no ground in a non metall airplane??
Best regards
The engine is made of metal thats where you usually ground it. Glow plug ignitors are a good example using the engine as the ground.
