RE: new drift car - froze up? Any ideas?
Check on your connectors to the motor, they may be loose, also check to make sure that the ESC is all the way into the receiver. I would suggest if none of this works, unplug the motor, then replug it in. On the Sprint 2, the engine connectors are easy to open. Not hard to close either. Good luck hope it helps.
