RE: Submerged my hobbycity lipo
As long as the cell packages aren't damaged allowing water in, you should be fine. Lithium reacts with water, so if there is a tear in the cell packaging, you shouldn't use it. Otherwise, the water is just in the exterior and once the water is dried out from the PCB and electrical joints, you should be ok.
