RE: should expo be used on 1st time trainer?
A control surface moves as far as its pushed (or pulled) by the rod.
A servo output is round, when around center the rod moves more with a given stick/servo movement than when the servo wheel is at the extreme of throw.
Hence the control surface will move more with a given stick input around center, than at the extremes of throw.
