ORIGINAL: blazer72
Thanx so much this fix did the trick. I was going crazy trying to get this to work you saved me so much frustration.I have been using my prizm radio for years its like an old shoe the conversion just made it all that much better.Thanx again Wheelsdown you are the man!
Hi Blazer72
You are very welcome. Glad it is fixed. I had decided that this problem was not going to beat me so I borrowed a friends Futaba which worked and checked it out.
I have since talked to Tony at Hitec and he informed me that pin 3 in the Prism 7X and other Hitecs is not connected to anything.
Question here is then why is pin 3 in the 2.4 module connect to something. Anyway it works now thank goodness. The 100K resistor I had added is not needed and pin 3 can be left empty.
Happy Flying
Gene
