RE: MODEL TECH 2M REMEDY
if you look at air flow from wind tunnel data you can see that turbulance is moved farther aft of trailing edge when the upper and lower edges are farther apart with faster planes the boundry layer is moved farther to the rear thus moving turblance farther aft
