RCU Forums - View Single Post - MODEL TECH 2M REMEDY
Old 10-21-2009 | 11:59 PM
go vertical
Default RE: MODEL TECH 2M REMEDY
look I am not going to get into a ball scraching contest if you want to taper the trailing edges go ahead do so. an f16 doesn't have the same peresentage cord wise as the remedy of the control surfasses the stabs are flying stabs that is a different set of rules the controle surfaces on a pylon racer are realy small
