RCU Forums - View Single Post - Katana S 140 CG location Help Needed!!!!
Old 10-22-2009 | 12:15 AM
jp928
Default RE: Katana S 140 CG location Help Needed!!!!
jIM,
Did yours require much weight to balance it please? I have a Moki 135 with BCM muffler, alloy spinner, 2oz nut, battery on side of engine box, elevator servos in front of wing tube, 8oz of lead on engine box, and its still tail heavy....
I will check your 242mm out from centre and see if its the same as Iam using. The 100-120mm back is the same as my book.
thanks
jp
