ORIGINAL: Bozarth
ORIGINAL: go vertical
the square trailing edges help in preventing flutter ...
Really? At the risk of oversimplifying the issue: Real F-16s have thin trailing edges, and so do propellers and Q500/Q40/FAI pylon planes. How fast does a Remedy have to go to encounter flutter, and how much faster can it go with thicker trailing edges and not encounter flutter? Will we really enjoy the prevention of flutter on a pattern plane due to thicker TEs? How thick is thick enough? How do we know? Inquiring minds want to know? [8D]
Kurt
F-16's and Pylon Racers are intended to go fast. Pattern planes aren't. When I went to my first pattern contest many years ago, I questioned why all the planes had blunt trailing edges, and was told that it was to improve response at low speed. Since then, I have also heard the flutter reason. The reason I have heard that makes the most sense to me is that it makes the plane draggier without affecting airflow over the flying surfaces to assist braking on the down lines.
