RE: TF Spitfire kit elevator/stab question
You may have done this but check to be SURE you used the correct LE for the elev. measure the plan thickness and then the material you used. Quite possible the cutter used the wrong thickness for the supplied sheet if thats were the leading edge came from. If that is the case, the other parts on that sheet will be wrong. If the leading edge was a ship loose stick, check for the correct one.
