I would do 3010 every where if futaba
if you use a engine synchronizer place 3010 on engine too cause they are precise
good luck on build
ORIGINAL: klazeem
Hi guys, just bought me a Tiger Cat..m not personally assembling the plane myself...but m supposed to get everything available to expedite the assembly...need some1's advice on which type of servo to be used on the plane...from the manual it says i need 13 servos...now i'm assuming standard size servos for all (i.e. futaba 3001 - torque 3.9kg/cm, speed 0.22 sec/
60°) for all..but i also heard that i need a more powerful servo for the elevator (i.e. metal gear servo / ultra torque)....can anyone point out if i'm headed in the right direction?....
