UCD with Saito 100 problem.
I've seen something similar happen to another UCD.
The problem was too much pressure and the high end needle was turned in to compensate. This gave a very sensitive mixture, and actually caused a deadstick that led to a crash destroying the plane. His needle valve was only open about 5/8 turn from fully closed.
Another flyer has that engine now and set it up at about 1 1/2 turns open, then back down the pressure until it runs right. No more problems!!
Just something to check for. Hope this helps.
