RE: TF Spitfire kit elevator/stab question
Nice work! The other note to make for later is to cut out a new cockpit floor or add some wood to the part in the kit so it matches the outline on the plan. Lay the part included with the kit over the plans and you will see what I mean when you get to that point. It comes up short. It will save you headaches when you go to sheet the fuse. Nice to see another Spit going together.
