RE: Reason for Engine Shutdown Identified?
Jeff
I know what you are feeling I went through the same things earlier this year. I sent the ECU back to Jetcat had them go through it. I also replaced the connectors to the ecu battery just for good measure and piece of mind. It lost power so I did what I could to all the power supply lines to the ECU. I have not had the problem since.
good luck with yours
Sincerely
Justin Sands
BVM rep
Team JR/Horizon
