RCU Forums - View Single Post - Apprentice 15e Nose wheel steering
Old 10-23-2009 | 08:16 AM
jarih
Default RE: Apprentice 15e Nose wheel steering
Thanks for the Tips, What I ended up doing was cutting the edges of the steering arm where the nsoe gear is inserted, seince the steering arm was originally installed from the back
you would need to remove the entire firewall to get it back in, with the edges trimed I sliped it in from the front, also I installed a larger and tougher nose gear since the original one is quite fragile also added 3 inch wheels it works on grass
Lets see if it works,
The plane is good and I enjoy the flights, I was actually looking at the T39, I am now thinking of getting the DH2 Eflite , it is a larger 68 inch span model should be fun to fly
