RE: two questions??????
Pretty much everything Joe said. You can cut it out under the epoxy then use shims to get it back to square. I have had the tail feathers slip while the epoxy was curing on a new build and had to do this. That always makes my day! Once epoxy cures it's pretty solid and I haven't found any way to remove it that comes out clean or easy.
