RCU Forums - View Single Post - SIG Rascal 40 Problem
Old 07-03-2003 | 02:33 AM
Salty25's Avatar
Salty25
My Feedback: (9)
Default Re: Mounts
Originally posted by Tcat1000
Get rid of that complete mount & replace it with a black composite mount. Drill the holes clear through the beams & use socket bolts, washers & lock nuts.
I use those mounts on all my other planes, never did like the metal mounts. The problem is this plane uses wooden beams for the engine to mount on. The plate is used to attach the motor to the beams. You can't take out the beams without destroying the nose of the plane. The nose is one solid piece on the plane, not a removable cowl as we are use to seeing.
I'm probably going to end up building another plate like this one, unless someone has an idea on what type of material to use that can withstand the vibration of a 4 stroke.
Thanks.
