RCU Forums - View Single Post - 3D TRAINER - PROFILE???
Old 10-25-2009 | 08:15 PM
  #31
beachbrada
My Feedback: (17)
Default RE: 3D TRAINER - PROFILE???
I got a couple flights in today with the Pro Yak and Saito 82 combo. This plane is a blast to fly, Im getting used to the difference in the power curve between the 55AX and Saito 82. It takes some time to get used to, the sound from the Saito is soo much more quiet compared to the 55AX that sometimes I think Im not giving enough throttle to hover but the plane is hovering anyway. Also torque roll compared to the 55 is almost non-existent. I could be hovering for 5 seconds no aileron input needed at all then I might get a slight torque roll, but its nothing compared to the 55. I had a little trouble with the battery, somehow it came loose inside the wing and made its way towards the wing tip, luckily I had a safety clip connecting the two wires together. I noticed whenever I got into a hover I the plane kept wanting to lean towards the left wing and I needed a lot of rudder to correct this. Sure enough when I got the plane and picked it up I could hear the battery moving around inside the wing.
