RE: Official HPI Hellfire Thread
SWEET!!! After I removed the sleeve, I got the piston and connecting rod out. Thanks for the help.
I hait to assume, but it's cheaper to rebuild versus buying a new enigine. I figured I would go ahead and replace the clyinder head, piston, sleeve, connecting rod, pin and c clip.
What is the difference in the washer that's between the cylinder head and piston sleeve?
Thicker: more compression
Thinner: less compression
Thanks again for your knowledge and help.
