RCU Forums - View Single Post - xxx-t problem AGAIN
Old 10-26-2009 | 07:14 AM
derek2005
Default RE: xxx-t problem AGAIN
Did you re-calibrate your radio to the esc when you got it back. I would:
Assuming your car is built right.
1. Re-set-up the ESC to the radio. (Make sure all connections are tight and you don't have any loose wires or solder connections)
2. Try a different battery
3. Try a different receiver/radio (if you have one)
If your esc is programmed to your radio and your car is built correctly, I would think this is an ESC problem.
