Glow Plug Issue
Generally, if the motor stops when you remove the ignitor, it indicates the plug is bad. It can't hold the heat from one stroke to the next. You may have ruined the plug by running too lean. If you have another plug, you could try that. Open the needle another half turn, it never hurts to be too rich.
Tom
