RCU Forums - View Single Post - Shrouded Prop? does it work?
Old 10-26-2009 | 02:58 PM
BMatthews's Avatar
BMatthews
Default RE: Shrouded Prop? does it work?
To do anything more than just produce turbulence the shroud needs to have a venturi like shaped lip that extends quite a ways in front of the prop blade. It's been a long time since I saw the article on inlet venturis for ducted fans bu I seem to recall that it needs to be at least 1.5 to 2 blade chords wide before it sees the prop disc. And have a good flare. Just adding a simple cylindrical ring won't do diddly and will actually hurt more than it helps. Another big issue was that the fan or prop needs to fit closely to the shroud. Gaps of even 1/16 inch caused so much drag adding turbulence that it took away a lot of the advantages. So you'd need to clip the blades to produce a flat end and then profile them on a lathe or some jig to shape the tips to match the shroud curve and leave only about a .020 to .030 gap. As well the shroud should extend back for a couple or more blade chord lengths to again ensure that the airflow doesn't suddenly turbulate due to the blades passing by.
So obviously to maintain such tight tolerances your shroud design needs to be structurally stiff and strong. And there's no guarantee that the gains will be worth the time and added weight. Not to mention that such a shroud has quite a bit of side and top view area. The tail surfaces would need to be enlarged to take this into account.
