RCU Forums - View Single Post - Shrouded Prop? does it work?
Old 10-26-2009 | 03:11 PM
Rotaryphile
Default RE: Shrouded Prop? does it work?
A shrouded propeller may nearly double static thrust per horsepower, which is great for VTOL airplanes, but the thrust advantage rapidly deteriorates to nearly zero as speed increases. In general, at normal cruise speed, the shroud's additional weight and drag negate any advantage.
