RE: Bashing of the Kadet Seniors
The Magnum .91 is on it,s way . Did,nt get to fly yesterday, just a crappy low cloud day. Ended up going to Menards and picking up another door blank for $5 bucks. The old one was getting a little beat up .
Going to build both wings at the same time, cut them outand theyjust fit a 80x30 door slab .The plans have shrunk about a 1/4 in. at thehe tips. The ribs are die-cut and I needed to go over most of the W-3 ribs wirh a razor blade, took some time but wellworth the effort in the long run.
Right wing trailing edge is good but left one has a pretty good curve in it . I was going to use the TE for theflaps and ali. so it well be cut up in 3 peice,s .I,ll try to straighten it but there is some harder wood on one end .
