RCU Forums - View Single Post - Battery advice
Old 10-27-2009 | 10:46 AM
dknovick's Avatar
dknovick
Default RE: Battery advice
ORIGINAL: flyboyfarr
Hey thanks dknovick I checked out ushobbysupply.com they have so many batteries to choose from and the 11.1v battery looks too big for the falcon 40. Any idea what type of lipo I should upgrade to?
The stock NiMH battery has a capacity of 700mAh, so something that size or larger. If you do use the 11.1V battery packs, I recommend the fuse protection for the 4in1. I also totally recommend upgrading to super skids. It will protect your bird from rough landings, and will be able to hold just able any size battery pack you throw at it.
Michael has both 7.4V and 11.1V 800mAh Lipos that would work very well.
Or you could try something in the range of 1100-1500mAh for an even longer run time.
I have a 11.1V 850mAh battery on my Falcon 40 and I get 10-15 mins of run time.
-Dave
