RE: MM Pro problems?
Maybe you can try the C.H.E.A.T. mode. It seems like in order to use it, you have to turn off the sensored to sensorless switching. I could be wrong, but it might be worth a shot. Doesn't take but a second to try it.
I'd also try the latest firmware. It was just updated to fix a rough sensorless startup. There's an off chance it might fix your issue.
