RCU Forums - View Single Post - Nutech 2wd oil fulled diff fitted to FG Marder
Old 10-27-2009 | 04:19 PM
bentley marshall
Default RE: Nutech 2wd oil fulled diff fitted to FG Marder
if you take them all the way apart you will find the orings there should be a oring and a plastic spacer on each axle and a oring on the main housing betwen both 1/2s
best way to clean the grease out is to use a bit of petrol will clean it up quick
