Hi all Tigercat builders and pilots. The new landing gear retrofits for worm gear drives are available for the KMP Generation 5 retracts. All three gear can be retrofitted by replacing the air cylinders in the retract mechanisms including the nose gear. You can now have a very scale retract operation that is more reliable. The three gear can be plugged into a JR matchbox or something equivelant and either be powered by your on board RX battery, (if the current drain on your RX isn't to high from all the servos) or the matchbox allows you to plug in an external battery that will power the wormgear drives. There is a video of the nosegear operation with the retrofit at Magnumrc.com.
http://magnumrc.com/index.php?main_p...products_id=14
