RCU Forums - View Single Post - TWM Nemesis .52 as 2nd plane?
Old 10-27-2009 | 07:50 PM
Campgems
Default RE: TWM Nemesis .52 as 2nd plane?
After getting my hands all over the Real Nemesis, I thought about scratch building one. I finally decided against it as the real plane is kind of unstable. One coment was that if the passenger brought along an extra tooth brush, it would screw up the CG. I've got to say that it is probably the sexistplane I've ever saw.
This ARF is a long ways from scale though, so it may fly better. Even then, Iwould hold off, or buy it while it's avaiable and put it aside until you've got a few more planes under your belt.
The Kosoho Kelly is another of the same type plane. One of the guys had one at the field and I was trying to get a couple air shots of it. It was so fast the when I locked it in the view finder at wide angle, it would be past us before I could start to zoom Igot two shots, way out, and the last one was about 10 seconds before the end of the plane. That pilot had flown quite a number of planes of all different sizes and styles. He mentioned that this was the hardest one he had ever flown, "you have to fly it evey second or it gone". Turns out that the failure that brough it down was the servo tray popping loose from glass fuselage. No pilot could have recovered from that.
The Nemesis though is a real eyefull
Don
ID:	1303258   Click image for larger version
