RCU Forums - View Single Post - New Hitec Aurora 9-Channel 2.4Ghz Radio System
Old 10-28-2009 | 06:12 PM
  #203
A.T.
Default RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
ORIGINAL: Alex7403 Thanks, Isnt there any simple and elegant charger like plug and charge without removing the battery? Alex
Yes, as describedpage 13 of Hitec 9ch Aurora 2.4GHz_72 mHz Manual using the 110/230 Vac charger, as included with some packages for both the Aurora and Optic Sport. Transmitter charge leadis fitted with a 1.3mm DC Power Line Female Connector. [1.3mm ID x 3.5 mm OD x 9.5 mm shaft length]
Manual indicates LEDchanges to green on completion of charge, this does not happen on all units - as all seen to date appear to simplydim out to no visiblelight .
Otherwise, to avoid possibledamage to a very nice transmitter, remove batteryand charge externallyas per a previous post.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
</p>
