RE: Sig Kadet JR first flight
TopGunn, I agree with the control throws to an extent.. I wouldn't say HIGH control throws... in the medium range would be good, because like I said you want to be able to get out of trouble and have enough control of the plane...
And the down elevator trim, every trainer will need this if you are flying above about half throttle.. just gotta compensate if you pop up the throttle because trainers to balloon at full throttle
