RCU Forums - View Single Post - DX6i and VPP Setup
Old 10-28-2009 | 09:47 PM
Don Szczur's Avatar
Don Szczur
Default RE: DX6i and VPP Setup
The other thing I learned was its easy to put too much positive pitch. I was wondering why the plane had more negative thrust than positive. Too much positive pitch loaded the motor down resulting in less rpm and less thrust in positive. I ended up putting the top of the throttle curve at 80 percent rather than 100 percent. If anyone is interested I can go through the programming by the numbers.
