RE: FS One by Hangar 9
Hi Adam,
your message is a bit confusing, but as I understand it, all the aircraft (both airplanes and helicopters) are listed correctly in the menu, but when you click on one (either airplane or helicopter) FSOne alerts you to a message that the image is not available. Is that correct?
Prior to the missing image info you mentioned that you installed onto a different laptop and it ran fine. Did this problem exist after your new install or only after the patches were loaded?
Scott
