RCU Forums - View Single Post - ESC/motor/prop combos
Old 10-29-2009 | 07:04 AM
beau0090_99's Avatar
beau0090_99
Default RE: ESC/motor/prop combos
If you can tell me what model the motors are, I could give you a good ballpark for what the 3S battery will do with various props using Drivecalc (assuming their data is in the database).
BTW, yeah, that is typically how I would do it. I wouldn't necessarily pick the largest prop, but one of nominal size. You wouldn't put a 4-6 inch prop on a 40 sized trainer, and you wouldn't put a 12 inch prop on your funjet. I figure this is the easiest way to start looking at combos.
Curtis
