RCU Forums - View Single Post - MODEL TECH 2M REMEDY
Old 10-29-2009 | 09:12 AM
  #52
go vertical
Default RE: MODEL TECH 2M REMEDY
the tail surfaces are slab also the remedy needs a diet with my ignition engine it weighes 12lb. with a OS160 it weighes 11 1/2 lb now I am useing a 2700 mah 5 cell that could be lighter a saito 150 or 180 would also help with the weight so if you plan on useing the remedy in compition you are going to have weight issues
