RCU Forums - View Single Post - Help with Exceed Blue Ray 450SE
Old 10-29-2009 | 11:58 AM
gnd2
Default RE: Help with Exceed Blue Ray 450SE
ORIGINAL: honda411
hi guys,
im looking for someone that can help me with my blue ray. What is happening is all of a sudden whenever im in normal mode for the throttle, the helicopter will rotate in a counterclockwise direction when i hit the collective up kinda fast. i know there is a torque factor here, but its never done it till today.
So what did you change between today and the last time you flew it, anything? Have you crashed? Is this problem only in normal mode and fine in idle up? Other than that, check the belt for correct tension and all the teeth still intact, it may have become worn out or loose causing it to slip.
One other thing is, if there is someone that has a good 3D setup on their transmitter that you could possibly send me either by email, or in a file or something, that would be fantastic!
The stock radio doesn't look programmable, do you have a programmable radio?
my 3D setup im guessing isnt that good because the heli will tend to drift sometimes doing loops and rolls. and my collective isnt straight and level all the way through the collective stroke. its starts with some right angle for the torque factor, and when at full collective, it has a small left angle. so my guess it the servos arent moving at the same pace.
I'm not sure what you're trying to say here but it sounds like your swash doesn't stay level through the full collective range? If that's the case, you just need to adjust it with sub trim and EPA until it's as close to level through the full range as possible. This is going to vary with every heli, no one elses settings are likely to help you with it. But again, you need a programmable radio, I'm not sure the stock radio is capable if that's all you have.
