ORIGINAL: goldswim5
Unless someone has a reason why these won't work, I think I'm going to make these my batteries to go with the 3000kv Outrunner and 30amp esc. This will keep the ''cheap as hell'' theme going too.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
2s lipo's at 3000 rpm's (7.4v x 3000 x 80% (losses) = 16,800 rpm's) is relatively slow. You'll want to use 3s or 4s (11.1 to 14.8v) to get into the upper 20's/lower 30's for a peppy boat. Which motor are you using?
ORIGINAL: ryanwilson277
whats the mounting hole distance for the motor mount in the tear into?
16mm.
