RCU Forums - View Single Post - Os Fs40
Thread: Os Fs40
Old 07-23-2003 | 04:19 PM
nimwegen
Default Os Fs40
Bill,
Well the engine is running just fine. I mounted it inverted in my little Waco bipe and it runs pretty good. I have trouble starting inverted, when I start setting the plane on it's wing, so now the motor is side ways, it will start fine. I have a feeling that the engine gets too much fuel. Also when idling after about 20sec or so it start run rough and will die after some time. I turned the airbleed needle out a lot but still see this. If I keep the glow driver on it idles much better. I can't do much about the tank position which might be a tad higher, any other suggestions.
Marcel.
