RCU Forums - View Single Post - Cub .25 pushrods
Old 10-30-2009 | 01:19 PM
bryris
Default Cub .25 pushrods
I've got this .25 Modeltech cub ARF that calls for some sort of epoxied wooden dowel type of pushrod setup. What I'd like to do is go with some semi flexible sleeved type pushrods instead. The distance from servos to surfaces is maybe 15 inches, hardly enough distance to allow any flex.
It is an ARF and is already covered. I guess with enough fidelity, I could drop a two holed crossmember into the fuse and run the pushrods through there for extra bracing.
Does this sound alright?
