RCU Forums - View Single Post - 8s Charge Setup
Old 10-31-2009 | 09:24 AM
dreadnaut's Avatar
dreadnaut
Default 8s Charge Setup
I finally did it. I am getting back into Pattern with a scratch built 8s electric setup. The plane is a scaled down version of the Gator Giles that I got plans for back when Gator was still around. I modified the wing to have double taper, moved the canopy forward, and made other changes. I'll be getting the laser cut parts next week, and will be getting the work shop prepared tomorrow.
Question; I just received 4x Zippy 4s4000mAh lipos, some 750mAh 2s reciever packs, and a GT Power A8 charger from HobbyKing. This charger has a port for an 8s balance connector, but HK (or anyone else for that matter) does not sell a 2x4s>8s adapter cable.[:@]. Do you guys running 8s setups make your own? How do you do this? Did I get the wrong charge setup?
Other info
AXI 4130-20
CC Ice 75 ESC
Jaccio 4.7v Reg (on order)
