RE: Kellogg's AD5 Skyraider Build
Glad to see your preparing to start construction. I have been working on the wing structure and I have started to sheet the bottom of the center section. I took the 48" piece of sheeting and cut it in half. It becomes the top and bottom of the center section. I made sure the bottom of the ribs had one final sanding to remove any excess glue and it would sit flat on the sheeting. I place the sheeting over the plans and glued the ribs and main spar from w1 to the wing split. I weighted and shimmed the wing to fit the sheeting tight to the ribs, tape the edges and now I wait for the glue to dry. See the pixs below!
To the golf course for a little more fun.....both of these hobbies can be frustrating!!!!!!!
