RCU Forums - View Single Post - Glue question
Thread: Glue question
Old 07-03-2003 | 03:48 PM
MajorTomski's Avatar
MajorTomski
Default Re: Glue question
Originally posted by Kristjan
What sort of glue to use between balsa and the covering material that you iron. Problem is that ironing itself doesn`t help anymore. The special glue is gone...
So I must put something by hand there. What should it be??
Kristjan
Kristjan, you can also use any wood glue, balsa right and balsaloc are just forms of this stuff. Brush a thin layer on the area you need to glue and LET IT DRY then try ironing on the plastic.
And
Just because you are a beginner, I have to ask; you HAVE REMOVED the clear backing sheet off of your iron on covering haven't you??? Not a dumb question, I've had THREE students show up at the flying field with covering applied this way. I have no idea how they get it to stick in the first place but you can do it.
