RE: Test Stand
I took two cutting boards as a mounting platform as suggested earlier in the thread. Prior to mounting I varnished the wood. I then mouned them to a craftsman work bench with two clamps. I was able to attach my OS SF .15 and get it running. The set up was ok but I found it hard to get the throttle stick to get a nice idle setting. The wire that moved around a lot because it is bendable and the lever was sticky. Other than those points it is an acceptable set up.
