ORIGINAL: studysession
Also need better tires. The rubber came unglued from the rims.
That's not a tire (or rim) issue, that's a TOOMUCHPOWER issue.
The original tires are pretty soft though, so you might want to pick up a set of a
harder compound than the stock Street Treads (and won't ballon as readily).
LOSB1166 - Rear, or even the LOSB1183 - Rear, are a better option for parking lot blasting ~~ and match up quite well with the new harder compound LOSB1172 -Fronts.
