Warbirdrcer
Always nice when you get out to fly. Hope you had a good day. Yes, you are correct the weights are PVC filled with copper nubs which are use to make copper cylinders for rotogravure printing. You could also use fishing weights. After I glued the ends on I sanded a flat on one side so they don't roll. I finished one of the pylons and installed the bomb release. They seam to good beautifully. I did have to modify my drawing. I will post the change after I redraw it. Hope to make a few more tonight.
SBD
LET GO PHILLIES!!!!!
