RCU Forums - View Single Post - SCALE JET e-S76 build
Old 11-02-2009 | 03:48 PM
  #60
bwellmaker
Default RE: SCALE JET e-S76 build
Some Powder Coating,
Nice. I think you should send your gear here, after powder coating, for me to look over and make sure its OK.
I am not sure of the hinges you have installed on your gear doors, but lets talk about that before you move forward. Depending on the hinge, just a longer arm may not be enough. With the hinges I used from BVM, the top of the door needed to be trimmed, and a filler will be added to the fuse so the door would open enough to be a work platform as the full scale.
With my install and hinges, the filler will only be about .195 or less. Its one of those trim to fit thingy
Here is a couple of pics
Butch
