RCU Forums - View Single Post - Installing torque rod help: Ultimate 40 kit build
Old 11-02-2009 | 04:46 PM
jigeye
Default Installing torque rod help: Ultimate 40 kit build
My first kit build and everything was going smoothly UNTIL.... (i'm sure you've heard this one before!)
Trying to install the torque rod for my elevators...
See 2 attachments
The problem seems to be the 3/32 drill bit hole is too large for what little balsa I have to work with. Trying to get it drilled into the soft balsa looks impossible without a drill press (of which I do not have).
What happens is the balsa splits and it seems impossible to drill the hole at a perpendicular angle to get the torque rod to have the correct angle.
There's got to be another way of doing this without a drill bit. I already cheated by putting tri-stock on my leading edge which worked great.
Looking for a tip/trick.
ID:	1306829   Click image for larger version
