RE: os .91 fs 4-stroke.
Ok Grey Beard, ya got me. Living proff that if you hang around long enough you will see and hear everything.
That being said, I was planning on mounting my Magnum Cylinder head down. There is an old thread in the Kit Building forum on a Tiger 60. That fella built a cowl around his engine and inverted it as well. It looked so clean. Lemme see if I have this right.
An inverted 4s would be mounted with the carb slightly lower than the fuel tank centerline. Correct? </p>
